several problems
Posted 24 mag 2012, 13:54 GMT-4 Structural Mechanics Version 4.2a 2 Replies
hi,
We bought the floating license and just installed on several computers a few weeks ago. As a newer, I am confused about the following questions. Could you help me to solve it?
1: I run a CAD model in a 32 bit operation system laptop, but I even can't do the mesh, for the comsol tells me " out of memory in meshing". But I can do the mesh in another
64 bit operation system laptop. Do you have any suggestion for me to run the comsol in the 32 bit operation system laptop?
2. To save the memory, which solver will you recommend? Mumps, Paroiso and Spooles. How to determine the relationship between memory and accuracy?
3 Error: the relative residual is greater than the relative tolerance. Can you give me some suggestions to solve this problem?
4.I mesh all parts separately and there is no warning or errors, however, the plot shows there are some edge didn't mesh well. If I select the a courser mesh method and to compute the model, the relative residual will be larger than the relative tolerance.
thanks
have a great day
Best!
thanks
have a great day
Best!
2 Replies Last Post 24 mag 2012, 21:15 GMT-4
