COMSOL programming
Hello, I want to generate random interpolation curve coordinate (xyz) using comsol program and my code follows
model.component(“comp1”).geom(“geom1”).create(“ic1”, “InterpolationCurve”); with(model.component(“comp1”).geom(“geom1”).feature(“ic1”)); int N = 100; double KK[][] = new double[N][3]; for (int k = 1; k < 100; k++) { KK[k][0] = Math.random(); KK[k][1] = Math.random); KK[k][2] = Math.random(); set("table", new double[][]{{KK[k][0], KK[k][1], KK[k][2]}}); } endwith();
table reads only (100th) last coordinate but I want all coordinates(100) in table. please help me.
Thanks Kiran
2 Replies Last Post 19 nov 2020, 05:19 CET
Posted: 5 years ago 18 nov 2020, 08:16 CET
I haven't tested it but I think this line will work:
set("table", KK);
and you want to put it outside your loop, but before endwith()
Lars Gregersen
Comsol Denmark
I haven't tested it but I think this line will work: set("table", KK); and you want to put it outside your loop, but before endwith()
Posted: 5 years ago 19 nov 2020, 05:19 CET
Hi Lars, Thanks for your reply. No, I does not work for me. I need to import the new XYZ coordinate for each iterlation from excel. so that I can generate new interpolation curve. Please do needful one.
Thanks Kiran
Hi Lars, Thanks for your reply. No, I does not work for me. I need to import the new XYZ coordinate for each iterlation from excel. so that I can generate new interpolation curve. Please do needful one. Thanks Kiran
