The Problem: the maximum gain is bigger than the maximum directivity.
In the attached file which is a microstrip antenna model, the value of maxGaindB is bigger than that of maxDdB. I couldn't find the reason. Do you have any idea?
Thanks.
2 Replies Last Post 17 set 2020, 19:27 CEST
Posted: 5 years ago 17 set 2020, 18:38 CEST
  1. Well, it's not much bigger, is it? And the materials in your design have no losses.
  2. I also suggest you compare the realized gain to the directivity.
  3. Consider also using a finer mesh.
1. Well, it's *not much* bigger, is it? And the materials in your design have no losses. 2. I also suggest you compare the *realized* gain to the directivity. 3. Consider also using a finer mesh.
Posted: 5 years ago 17 set 2020, 19:27 CEST
Hi Robert,
Should I accept this situation as they are almost same but the small calculation errors causes this result. If so, I won't worry about it.
  1. I also suggest you compare the realized gain to the directivity.
I had done it. Realized gain = 7.3393, directivity = 7.3388. The gain is winner again :).
  1. Consider also using a finer mesh.
The results obtained with extremelly fine meshes: Maximum directivity, dB: 7.3388 Maximum gain, dB: 7.4306 Maximum realized gain, dB: 7.3393.
Thank you.
Hi Robert, >1. Well, it's *not much* bigger, is it? And the materials in your design have no losses. Should I accept this situation as they are almost same but the small calculation errors causes this result. If so, I won't worry about it. >2. I also suggest you compare the *realized* gain to the directivity. I had done it. Realized gain = 7.3393, directivity = 7.3388. The gain is winner again :). >3. Consider also using a finer mesh. The results obtained with extremelly fine meshes: Maximum directivity, dB: 7.3388 Maximum gain, dB: 7.4306 Maximum realized gain, dB: 7.3393. Thank you.
