1 mar 2012, 20:35 CET
no point is "created" but a Data set structure with all variables interpolated to the geometrical point you defined. So you then access the data set as a Point Graph pointing to the given data set to "see" the values, or you apply an operator to it or wahtever
4 apr 2013, 17:59 CEST
I have a question that is very similar to that originally asked.
I have created 2 cut point 3D data sets. Essentially I am interested in looking at the voltage values at the 2 points. These points are not part of the geometry. In my derived values section, I create point evaluations for the 2 points. I can evaluate the point evaluations and look at the voltage values at the points individually. Now I am interested in looking at the potential difference between the 2 points. How do I do that? Obviously, I do not want to do the subtraction manually.
4 apr 2013, 23:29 CEST
the best is to make them part of the geometry, and then define variables on them in the Model Definitions Variable node(s)
Magnus Ringh
COMSOL Employee
5 apr 2013, 08:58 CEST
You can also use a Join data set where you use the first Cut Point 3D data set as Data 1 and the second Cut Point 3D data set as Data 2, and then use Difference as the combination method. Evaluating the Join data set as a Point Evaluation then gives you the potential difference between the voltages in the two points.
Magnus Ringh, COMSOL
5 apr 2013, 09:03 CEST
Hi Magnus
that's a possibility I often forget about, good point ;)
Hi Magnus
