Impossible to Couple Lubricant Shell with Solid Mechanics
Francesc-Xavier Borras
Lubrication Shell: Thin film between the solid wall and the channel base.
The edge you select is the "solid wall" and if that edge is from a "solid mechanic" domain then you can couple it with the "lubrication shell" (Solid Wall Defromation)
However, the software does not ask you for any adge to define the "Channel Base", how does it know the propieties of the "Channel Base"? How to define the "Channel Base"?
Thanks again.
2 Replies Last Post 21 feb 2012, 11:43 CET
Posted: 1 decade ago 21 feb 2012, 08:51 CET
I attach a simplified model in 2D.
Here I tried to model both parts (pad and runner).
I assigned the Lubricant Shell Physics to both edges
In the Lubricant Shell/Gap Proprieties: I coupled the "displacement of the solid wall" with the "Solid Mechanics". I would like to couple the "displacement of the channel base" too. Why I do not have this possibility?
The software do not know which is the channel base?
Check it please.
I attach a simplified model in 2D. Here I tried to model both parts (pad and runner). I assigned the Lubricant Shell Physics to both edges In the Lubricant Shell/Gap Proprieties: I coupled the "displacement of the solid wall" with the "Solid Mechanics". I would like to couple the "displacement of the channel base" too. Why I do not have this possibility? The software do not know which is the channel base? Check it please.
Posted: 1 decade ago 21 feb 2012, 11:43 CET
Anyone knows who did the tutorial from "Tilted Pad Thrust Bearing". Model ID: 7077
www.comsol.com/showroom/gallery/7707/
I would be really glad to conctact him.
Anyone knows who did the tutorial from "Tilted Pad Thrust Bearing". Model ID: 7077 http://www.comsol.com/showroom/gallery/7707/ I would be really glad to conctact him. Thanks,
