How to get displacement versus time graph from velocity versus time graph
Hi all,
In one of my simulations, I got v-t graph. Now I want x-t graph (x=displacement, not distance) . I know that I have to find the area under the graph. I used evaluation->line integral->chose the boundary and typed velocity*time. Is it right?
With regards
Siva
2 Replies Last Post 6 feb 2012, 12:55 CET
Posted: 1 decade ago 6 feb 2012, 08:34 CET
in which physics are you ? if its solid, the displacement is u,v,w the dependent variable elements
if you are in CFD you solve for the velocity so you must integrate the velocity either with an ODE or the timeint() operator (new in 4.2a)
Hi in which physics are you ? if its solid, the displacement is u,v,w the dependent variable elements if you are in CFD you solve for the velocity so you must integrate the velocity either with an ODE or the timeint() operator (new in 4.2a) -- Good luck Ivar
Posted: 1 decade ago 6 feb 2012, 12:55 CET
Thank you very much Dr. Ivar.
I have selected 2D flow (spf) physics. And using accelerated frame (body-fitted) of reference. I have solved for velocity and have the data.
timeint() is indeed very useful.
I was wondering what we get is distance (path length or actual distance travelled -scalar) or displacement (shortest distance -vector)?
With regards
Siva
Thank you very much Dr. Ivar. I have selected 2D flow (spf) physics. And using accelerated frame (body-fitted) of reference. I have solved for velocity and have the data. timeint() is indeed very useful. I was wondering what we get is distance (path length or actual distance travelled -scalar) or displacement (shortest distance -vector)? With regards Siva
