Schrodinger-Poisson Parametric Sweep
Posted 10 dic 2019, 20:49 GMT-5 Semiconductor Devices Version 5.4 0 Replies
I would like to determine the wave functions for multiple quantum well models with varying well/barrier dimension; i.e. one model with one set of parameters repeated (2/5/2/5/2), and another with a second repeated parameter set (3/5/3/5/3).
When adding a Parametric Sweep to the Study, the only useful results I can get with the Parametric Solutions Data Set is the voltage [V] and potential energy schr.V [eV]. If I try to use the Parametric Solutions Data Set to plot the wave functions using the equation
schr.Psi*0.05[eV]/schr.plot_fac +schr.Ei
I get the error:
Cannot evaluate expression. Undefined variable. - Variable: lambda - Geometry: geom1 - Domain: 15 Failed to evaluate variable. - Variable: comp1.schr.Ei - Defined as: comp1.schr.lambda_scalelambda Failed to evaluate expression. - Expression: 6.2415091258832579E18(8.010883104E-21*comp1.schr.Psi/comp1.schr.plot_fac+comp1.schr.Ei) - Plot: lngr2 (Line graph)
The results associated with the Study 1/Solution Store: Store Wave Function are only for one parameter, rather than a sweep.
If I try to do my sweep using the Study Extensions- Auxiliary Sweep node under Schrodinger-Poisson/Settings a warning pops up under the Eigenvalue Solver 1: Solve for Wave Function- "Parametric Solver does not support varying parameters in geometry or mesh. Use Parametric Sweep for this."
Can anyone help me with this issue?
Thank you!
Hello Catherine O'Hearn
