How to setup a periodic Boundary condition with automatic remeshing?
Posted 20 ott 2019, 21:39 GMT-4 Heat Transfer, Microfluidics, Mesh Version 5.3a 1 Reply
I have a laminar flow problem coupled with heat transfer. The domain is periodic in the lateral direction, so I use the periodic flow condition for laminar flow and the periodic flow condition for heat transfer in solid. I have the copy I node in the mesh generated by physics-controlled mesh setting.
It works fine with I don't have automatic remeshing enabled. If I want to implement automatic remeshing (because the fluid interface deforms quite severely and the mesh quality becomes quite poor), then it gives an error when remeshing occurs. It says 'Failed to build feature 'Copy 1' in sequence 'Mesh 1'. Geometry object and mesh object are not compatible. Vertex coordinates differ.'.
So it looks like there is some problem with the copy 1 node related to periodic boundary condition. What does it mean for vertex coordinates to differ? How to solve this problem?
