Robert Koslover
Certified Consultant
5 years ago
11 gen 2019, 17:13 CET
Updated:
5 years ago
11 gen 2019, 17:24 CET
I have the RF module, which is similar to the Wave Optics module. In principle, the software will allow you to specify (via entering equations, as you already noted) a full vector E field as a function of x,y,z under the "initial values" setting for the domain of interest. However, any arbitrary configuration of fields, or of field directions (aka, polarization) may not satisfy Maxwell's equations. So... you might want to re-think your plans here, since presumably you are interested in modeling real-world physics. In most cases, that means imposing user-specified constraints only upon fields, currents, and charges at locations that are limited to what you actually know to be true in the problem of interest to you. You can then allow Comsol Multiphysics to compute the fields everywhere else.
I should add: Check to see if your module supports the wave-scattering formalism. This lets you impose a (initially unperturbed) plane-wave throughout the volume. A common application is radar cross-section work, but that isn't the only application. Also, this isn't truly an "arbitrary" field specification in terms of x,y,z, but even so, you can specify a plane wave (in a fixed direction that you also specify) with "arbitrary polarization." So maybe that is close enough to what you are looking for? Good luck.
I have the RF module, which is similar to the Wave Optics module. In principle, the software will allow you to specify (via entering equations, as you already noted) a full vector E field as a function of x,y,z under the "initial values" setting for the domain of interest. However, any *arbitrary* configuration of fields, or of field directions (aka, polarization) may not satisfy Maxwell's equations. So... you might want to re-think your plans here, since presumably you are interested in modeling real-world physics. In most cases, that means imposing user-specified constraints only upon fields, currents, and charges at locations that are limited to what you actually *know* to be true in the problem of interest to you. You can then allow Comsol Multiphysics to *compute* the fields everywhere else.
I should add: Check to see if your module supports the wave-scattering formalism. This lets you impose a (initially unperturbed) plane-wave throughout the volume. A common application is radar cross-section work, but that isn't the only application. Also, this isn't truly an "arbitrary" field specification in terms of x,y,z, but even so, you can specify a *plane wave* (in a fixed direction that you also specify) with "arbitrary polarization." So *maybe* that is close enough to what you are looking for? Good luck.
