Complex Eigenvalues in general form PDE with no damping
Posted 5 set 2011, 11:57 GMT-4 Version 4.1, Version 4.2 4 Replies
Dear all,
Hi. I have faced a problem in implementing the eigenvalue study for solving a structure modeled in the General Form PDE interface. I have applied the general Navier equations for modeling the structure. For a simple beam, first I studied the Stationary solution and I validated the results with the same beam modeled in the structural module. Also I checked the Stiffness Matrix, Mass Matrix and ... . Which were exactly same for the stationary solution for both my model (Math module) and the Structural module. When implementing the solution for eigen value study, I found difference between results. It was interesting. What I observed:
1) Complex Eigen Values were obtained while the term of damping "da is 0" in
"ea*(d^2u/dt^2)+da(du/dt)+Nabla.gamma=0
2) Damping matrix was non-zero. (It was really unexpected)
3) The stiffness Matrix had changed for the Math module while not for the structural module comparing to stationary solution.
I appreciate your comment on this issue. How can an equation with no damping term has complex eigenvalues as well as
Masoud
Masoud
4 Replies Last Post 7 set 2011, 15:47 GMT-4
