2 ago 2011, 17:03 GMT-4
Can you upload a copy of your code?
4 ago 2011, 01:56 GMT-4
Try to make metal dieletric interface very long so plasmon will be damped by losses. (Although it will need very big mesh.)
Or use Perfectly matched layers.
4 ago 2011, 03:31 GMT-4
Hi Guys,
Thank for your responses but I found the problem - it seems the COMSOL demands that the complex nature of losses be negative! it is due to definitions of the coordinate directions and wave propagation. this does not appear in the documentation but this issue resolves correct losses and propagation directions.
FYI!
Hi Guys,
FYI!
4 ago 2011, 03:57 GMT-4
I am sorry but I do not understand what you mean by "COMSOL demands that the complex nature of losses be negative!"
4 ago 2011, 04:18 GMT-4
In order for the metal to show losses you must define its epsilon as complexed. and the sign of the complex part must be defined as negative to creae losses, if you define it as positive it will generate power and not absorb it. this also effect the propagation direction of waves since the wave is EXP(i*k*x).
Itai.
Itai.
4 ago 2011, 04:21 GMT-4
It is specified at pages 121-122 of RFModuleUsersGuide.pdf
4 ago 2011, 04:33 GMT-4
I am sorry, I dont see it, what version are you using?
4 ago 2011, 04:34 GMT-4
Version 4.2
Version 4.2
4 ago 2011, 04:41 GMT-4
I am using 3.5a so maybe they added that...
