Air in solidmechanics
Dear Sir ,
How can I model air density and elastic modulus in solid mechanics module case using multiphysics ???
2 Replies Last Post 7 lug 2011, 00:38 CEST
Posted: 1 decade ago 5 lug 2011, 09:20 CEST
Dear Sam,
Try to use fluid-structure interaction modules[FSI] under CFD which couples both physics of fluids and solid mechanics . But you have mentioned modelling density and elastic modulus which can be done by choosing "user-defined" for density and elastic modulus seperatly in this interface as per your design.
good luck
vijay g
Dear Sam, Try to use fluid-structure interaction modules[FSI] under CFD which couples both physics of fluids and solid mechanics . But you have mentioned modelling density and elastic modulus which can be done by choosing "user-defined" for density and elastic modulus seperatly in this interface as per your design. good luck vijay g
Posted: 1 decade ago 7 lug 2011, 00:38 CEST
Thanks ... I AM USING ELECTRIC AND MAGNETIC FIELDS .... with the solid mechanics so I need to know exactly what is the elastic modulus case I am modeling magnetic field varying with the dynamics of structure...
