Using a certain temperature of the geometry (for example a point on a surface)
Posted 10 mag 2011, 06:26 GMT-4 Heat Transfer & Phase Change 2 Replies
I want to make a model in the heat transfer module in order to cool down a small cylinder with a water jet. Therefor I need to define the heat transfer coefficient in function of the temperature of the surface. what is the common way to introduce a certain temperature of a point in your geometry (cordinates) to use this temperature in your setting of the HTC value?
2 Replies Last Post 10 mag 2011, 09:02 GMT-4
