FSI
Posted 20 apr 2018, 12:01 GMT-4 Fluid & Heat, Structural Mechanics Version 5.2a 0 Replies
i am doing the fluid structure interaction using the Comsol modal library named vibrating beam in the fluid flow. and I want to scale down the model. the default beam dimensions are in meters. If I am changing the dimension to cm. the solution does n
I want to scale down the model such that the thickness is aroung 1/2 mm. . . I have tried changing the dimentions manually in meter scale too but that is also not working. . .
Hello P. C. Rajgopalan
