Does anyone know how to assign spatial-dependent vectorial values to a Control variable field when using Sensitivity Analysis module? In the Sensitivity interface, I can only specify a scalar to the property "Initial value"
Does anyone know how to assign spatial-dependent vectorial values to a Control variable field when using Sensitivity Analysis module? In the Sensitivity interface, I can only specify a scalar to the property "Initial value."
Because I am now using the Livelink Matlab to manipulate the Sensitivity module to compute the partial derivative of a scalar objective(OBJ) function with respect to a control variable field ("rho", which is spatial-dependent) defined over a domain, I'd like to get the derivative of the OBJ with respect to an arbitrary control variable field "rho", which should be coordinate(x, y) dependent. However, it seems like in the Sensitivity interface the only way to assign a value to the "rho" is through the "Initial value," which only supports scalar input.
Thanks, Bryant
0 Replies Last Post 23 mar 2018, 18:41 GMT-4
Hello Jinlong Zhu
