calculation of current of metal plate_infinite element domain
We have one question about calculation of current of metal plate.
Attached model uses Magnetic fields and is built in 5.2a version.
One layer of infinite element domain is defined around the outside of the air domain.
Unfortunately, the converged solution cannot be achieved. The message always shows that 32% progress and the computation cannot go further.
On the other hand, the solution will be done if there is no infinite element domain.
Does that mean we could not use infinite element domain in this case?
Thank you very much.
2 Replies Last Post 22 nov 2016, 01:02 CET
Posted: 9 years ago 21 nov 2016, 11:03 CET
Jing Wang,
the infinite element domain has to cover the end faces too. The documentation shows the geometry examples.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Jing Wang, the infinite element domain has to cover the end faces too. The documentation shows the geometry examples. Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
Posted: 9 years ago 22 nov 2016, 01:02 CET
Dear Edgar J. Kaiser,
Thank you very much for your help : )
Jing Wang
Dear Edgar J. Kaiser, Thank you very much for your help : ) Best regards, Jing Wang
