parametric volume: tapered cylinder
I'm trying to make a cylinder-like solid which tapers from a circular cross-section at one base to an elliptical cross-section at the other base. This can be represented with a parametric surface:
x = s1 ⨉ L
y = R ⨉ sin(2π s2)
z = R ⨉ [ (1 + α)/2 + ½ (1 – α) cos(2π s1)] cos(2π s2)
Here R is the radius of the circle and the major radius of the ellipse. The minor radius of the ellipse is αR. The length of this quasi-cylinder is L.
However, this is a surface, and while I have tried "convert to solid", I get that the surface is empty. I try adding end caps, defined as additional parametric surfaces, but these don't fit perfectly, and again convert to solid fails.
An alternate scheme would be to make an encapsulating cylinder of radius R and partition it with the surface, subsequently deleting the outer partitions. But I can't figure out how to do the partitioning in this way (I tried but it didn't work).
Any advice?
9 Replies Last Post 28 ott 2016, 08:41 GMT-4
Posted: 9 years ago 25 ott 2016, 22:47 GMT-4
The answer is actually in the documentation, which I'd applied to the cylinder, but not to the end caps.
Instead of using a self-closing surface, partition it into two half-surfaces:
x = s1 ⨉ L
y = R ⨉ sin(π s2)
z = R ⨉ [ (1 + α)/2 + ½ (1 – α) cos(2π s1)] cos(π s2)
and
x = s1 ⨉ L
y = R ⨉ sin(–π s2)
z = R ⨉ [ (1 + α)/2 + ½ (1 – α) cos(2π s1)] cos(–π s2)
The end-caps are then semi-circles:
x = 0
y = R ⨉ s1 ⨉ cos(π s2)
z = R ⨉ s1 ⨉ sin(π s2)
x = 0
y = R ⨉ s1 ⨉ cos(–π s2)
z = R ⨉ s1 ⨉ sin(–π s2)
and semiellipses:
x = L
z = R ⨉ α ⨉ s1 ⨉ sin(π s2)
x = L
z = R ⨉ α ⨉ s1 ⨉ sin(–π s2)
When I use these as the elements for "convert to solid" I get what I want.
The answer is actually in the documentation, which I'd applied to the cylinder, but not to the end caps. Instead of using a self-closing surface, partition it into two half-surfaces: x = s1 ⨉ L y = R ⨉ sin(π s2) z = R ⨉ [ (1 + α)/2 + ½ (1 – α) cos(2π s1)] cos(π s2) and x = s1 ⨉ L y = R ⨉ sin(–π s2) z = R ⨉ [ (1 + α)/2 + ½ (1 – α) cos(2π s1)] cos(–π s2) The end-caps are then semi-circles: x = 0 y = R ⨉ s1 ⨉ cos(π s2) z = R ⨉ s1 ⨉ sin(π s2) x = 0 y = R ⨉ s1 ⨉ cos(–π s2) z = R ⨉ s1 ⨉ sin(–π s2) and semiellipses: x = L y = R ⨉ s1 ⨉ cos(π s2) z = R ⨉ α ⨉ s1 ⨉ sin(π s2) x = L y = R ⨉ s1 ⨉ cos(–π s2) z = R ⨉ α ⨉ s1 ⨉ sin(–π s2) When I use these as the elements for "convert to solid" I get what I want.
Posted: 9 years ago 26 ott 2016, 09:05 GMT-4
Hello Daniel,
An alternative approach is to use the "Cap Faces" capability. One benefit of it is that it applies even when there is no known analytical expression for the end caps.
A simple example taken from the CAD Import Module webpage is here:
cdn.comsol.com/products/cadimport/capping_550x450_color.png
That image does not really do "Cap Faces" justice since the capping face is planar and "boring"; like I said above, this can be used even if the end cap does not have a known analytical form.
"Cap Faces" is one of the advanced geometry operations that come with the CAD Import Module, Design Module and LiveLink for CAD products.
Hello Daniel, An alternative approach is to use the "Cap Faces" capability. One benefit of it is that it applies even when there is no known analytical expression for the end caps. A simple example taken from the CAD Import Module webpage is here: https://cdn.comsol.com/products/cadimport/capping_550x450_color.png That image does not really do "Cap Faces" justice since the capping face is planar and "boring"; like I said above, this can be used even if the end cap does not have a known analytical form. "Cap Faces" is one of the advanced geometry operations that come with the CAD Import Module, Design Module and LiveLink for CAD products. Best, Jeff
Posted: 9 years ago 26 ott 2016, 12:27 GMT-4
Thanks, Jeff! Coming up with analytic representations of smooth surfaces is part of the fun, but your suggestion is an excellent one, and motivates an expansion of our set of our license set here.
One issue: the structure I have consists of six surfaces and one conversion operation with a structure defined by essentially 3 parameters. It seems to me to be a natural application for a macro specification: provide the macro with the three parameters, automatically get the given structure. I am reminded of POV-Ray, a ray-tracer which has geometric primitives controlled with a simple text language, where such macros are possible, and almost essential for the construction of non-trivial scenes. The structure I'm simulating (for fun and learning, not directly for research) would use this macro-object 4 times, although better would be two instances of macros which each use the macro-object twice. So is there a recommended approach to this without abandoning the GUI in favor of Matlab, which is a direction I'd prefer to not go?
Thanks, Jeff! Coming up with analytic representations of smooth surfaces is part of the fun, but your suggestion is an excellent one, and motivates an expansion of our set of our license set here. One issue: the structure I have consists of six surfaces and one conversion operation with a structure defined by essentially 3 parameters. It seems to me to be a natural application for a macro specification: provide the macro with the three parameters, automatically get the given structure. I am reminded of POV-Ray, a ray-tracer which has geometric primitives controlled with a simple text language, where such macros are possible, and almost essential for the construction of non-trivial scenes. The structure I'm simulating (for fun and learning, not directly for research) would use this macro-object 4 times, although better would be two instances of macros which each use the macro-object twice. So is there a recommended approach to this without abandoning the GUI in favor of Matlab, which is a direction I'd prefer to not go?
Posted: 9 years ago 26 ott 2016, 13:30 GMT-4
If I catch your drift you're talking about what COMSOL calls "Geometry Parts" (Formerly "Geometry subsequences"). More info on that concept is available here: www.comsol.com/release/5.1/mesh-and-geometry
Check out also the file at the link below for an example where I used the concept to rapidly draw a bunch of dominoes.
cds.comsol.com/mg/b5810e700585bd.zip
Estimated size: 3.7 MB
This link expires November 2, 2016. Please make sure to download before that date.
Included files:
- 5p2_Domino_Small.mph
If I catch your drift you're talking about what COMSOL calls "Geometry Parts" (Formerly "Geometry subsequences"). More info on that concept is available here: https://www.comsol.com/release/5.1/mesh-and-geometry Check out also the file at the link below for an example where I used the concept to rapidly draw a bunch of dominoes. ------------------------------------------- http://cds.comsol.com/mg/b5810e700585bd.zip Estimated size: 3.7 MB This link expires November 2, 2016. Please make sure to download before that date. Included files: - 5p2_Domino_Small.mph ------------------------------------------- Best, Jeff
Posted: 9 years ago 26 ott 2016, 16:03 GMT-4
Thanks! Here's my object, which was implemented with a 2nd-order continuous function implemented with an "if" function on the parametric surfaces (top and bottom), with 4 more parametric surfaces for the two end-caps.
i.imgur.com/3lmzd2J.png
Thanks! Here's my object, which was implemented with a 2nd-order continuous function implemented with an "if" function on the parametric surfaces (top and bottom), with 4 more parametric surfaces for the two end-caps. http://i.imgur.com/3lmzd2J.png
Posted: 9 years ago 26 ott 2016, 16:54 GMT-4
That's fantastic! Although I admit I'm quite disappointed with the scope of the implementation. I was expecting something more in the time-dependent structural mechanics realm, perhaps exercising the contact model with friction, for example something like:
www.youtube.com/watch?v=ARM42-eorzE
although this would also have required modeling rolls of duct tape.
That's fantastic! Although I admit I'm quite disappointed with the scope of the implementation. I was expecting something more in the time-dependent structural mechanics realm, perhaps exercising the contact model with friction, for example something like: https://www.youtube.com/watch?v=ARM42-eorzE although this would also have required modeling rolls of duct tape.
Posted: 9 years ago 26 ott 2016, 18:07 GMT-4
:) I'll get right on it.
:) I'll get right on it. Jeff
Posted: 9 years ago 27 ott 2016, 19:12 GMT-4
While you're working on that, I've been doing something similarly relevant. The analytic solids are the two tapered top sections, tapering from circular cross-section to eccentric cross-section. This is investigating the impact of an isoareal eccentric cross-section, designed for aerodynamics, on stiffness. The whole thing is hollow with a 1.3 mm wall thickness (except in the eccentric section where the wall thickness is non-uniform), the result of liberal use of boolean differences.
i.imgur.com/axqSPPn.png
While you're working on that, I've been doing something similarly relevant. The analytic solids are the two tapered top sections, tapering from circular cross-section to eccentric cross-section. This is investigating the impact of an isoareal eccentric cross-section, designed for aerodynamics, on stiffness. The whole thing is hollow with a 1.3 mm wall thickness (except in the eccentric section where the wall thickness is non-uniform), the result of liberal use of boolean differences. http://i.imgur.com/axqSPPn.png
Posted: 9 years ago 28 ott 2016, 08:41 GMT-4
You might like this app:
www.comsol.com/model/bike-frame-analyzer-35101
You might like this app: https://www.comsol.com/model/bike-frame-analyzer-35101 Jeff
