Problem using Comsol 4.0a and MATLAB
I am quite new to Comsol, we are using it for an university project.
I try to simualte an electrostatic actor and in oder to be able to move different electrodes i want to use parameters. Using parameters for rectangles and for example circles works perfectly fine, but as soon as I am using points its not working anymore.
Here is a very basic example code for the creation of a point using parameters:
model = ModelUtil.create('Model');
model.param.set('a','0.2');
model.geom().create('geom1',2);
model.geom('geom1').feature.create('p1','Point');
model.geom('geom1').feature('p1').set('p',{'a','2'});
model.geom('geom1').run;
mphgeom(model,'geom1');
And here is the error message generated by MATLAB:
??? Java exception occurred:
Exception:
com.comsol.util.exceptions.FlException: Unknown variable name
- Name: a
- Property name: p
Stack trace:
at com.comsol.util.classes.o.a(Unknown Source)
at com.comsol.util.classes.o.b(Unknown Source)
at com.comsol.nativeutil.parser.ParseUtil.e(Unknown Source)
at com.comsol.nativeutil.parser.ParseUtil.a(Unknown Source)
at com.comsol.nativeutil.properties.ai.set(Unknown Source)
at com.comsol.model.impl.PropValueImpl.set(Unknown Source)
at com.comsol.model.impl.PropFeatureImpl.c(Unknown Source)
at com.comsol.model.impl.PropFeatureImpl$p.a(Unknown Source)
at com.comsol.model.impl.PropFeatureImpl$p.execute(Unknown Source)
at com.comsol.model.clientserver.ClientManagerImpl$d.call(Unknown
Source)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
at java.util.concurrent.FutureTask.run(FutureTask.java:138)
at
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:680)
Error in ==> Actor_MATLAB_Handwritten at 10
Any ideas what I am doing wrong?
Michael
1 Reply Last Post 2 dic 2010, 18:07 CET
Posted: 1 decade ago 2 dic 2010, 18:07 CET
it could be a naming conflict, most single eltter are already used by COMSOL, I always use at least 2 lettre names, or even adding a "_1" or "_mine" suffix.
Normally COMSOl tells you but often you are allowed to modify the internal variables soCOMSOl cannot always tell if it is allowed/intentional or not to use the same name
Hi it could be a naming conflict, most single eltter are already used by COMSOL, I always use at least 2 lettre names, or even adding a "_1" or "_mine" suffix. Normally COMSOl tells you but often you are allowed to modify the internal variables soCOMSOl cannot always tell if it is allowed/intentional or not to use the same name -- Good luck Ivar
