Problem generating a movie
I am trying to generate animation of time-harmonic magnetic field. I know the solution is OK, because when I change the phase angle in post-processor settings I see the results change. But when I try generating the animation, it generates "movie" with the same static frame. I noticed that it also happens with transient problems from the model library. Is it the problem with Comsol or with my video-codecs? How can I fix it? Thanks in advance.
5 Replies Last Post 4 mar 2010, 14:25 GMT-5
Posted: 1 decade ago 4 mar 2010, 01:48 GMT-5
could it be that you have not set correctly the phase value in the general tab to point to the imaginary part ?
Hi could it be that you have not set correctly the phase value in the general tab to point to the imaginary part ? Good luck Ivar
Posted: 1 decade ago 4 mar 2010, 09:50 GMT-5
Hi Ivar,
It is possible, what is the correct way to set this value?
Hi Ivar, It is possible, what is the correct way to set this value? Thanks [QUOTE] Hi could it be that you have not set correctly the phase value in the general tab to point to the imaginary part ? Good luck Ivar [/QUOTE]
Posted: 1 decade ago 4 mar 2010, 10:38 GMT-5
I've also been having this problem with a time dependent model. The animation correctly steps through the time sequence when making the movie, but when it comes to playing it afterwards it has just put in the first step for every frame.
Robert
I've also been having this problem with a time dependent model. The animation correctly steps through the time sequence when making the movie, but when it comes to playing it afterwards it has just put in the first step for every frame. Robert
Posted: 1 decade ago 4 mar 2010, 10:58 GMT-5
I have faced the same problem a year ago. I could not understand exactly but I think is more related to the rendering or Java stuff!! As I was using Ubuntu, so I have created the animation movie by using COMSOL in Windows and the problem was "solved"!!
I hope it helps
Cheers
I have faced the same problem a year ago. I could not understand exactly but I think is more related to the rendering or Java stuff!! As I was using Ubuntu, so I have created the animation movie by using COMSOL in Windows and the problem was "solved"!! I hope it helps Cheers
Posted: 1 decade ago 4 mar 2010, 14:25 GMT-5
I have no particular problem with the movies (UX RedHat I believe), but I know that some of the RF modes are appearant as imaginary parts only. hence one must set the phase to 90° in the postprocessing general tab, but from the moment one can select manually the time sequence and plot it out image by image, then the movie/animation should work I agree, except perhaps if the movie format is not in line with the installed drivers, or that, as other are saying, there is a Java or movie I/F issue.
Cannot do better
Hi I have no particular problem with the movies (UX RedHat I believe), but I know that some of the RF modes are appearant as imaginary parts only. hence one must set the phase to 90° in the postprocessing general tab, but from the moment one can select manually the time sequence and plot it out image by image, then the movie/animation should work I agree, except perhaps if the movie format is not in line with the installed drivers, or that, as other are saying, there is a Java or movie I/F issue. Cannot do better Good luck Ivar
