Multiple MEMS devices in parallel using electrical circuit physics ?
Here is my model: I am simulating a micro piezoelectric systems. The simulation is complex and can take some time. Then, I use the electrical circuit physics to simulate my systems with an output circuit.
But the full device is build with an array of hundreds of piezoelectric systems in parallel. And it is impossible for me to simulate hundreds of systems with the piezoelectric physics (to much computer ressources).
So my question is simple:
It is possible to simulate only one systems with the piezoelectric physics and, with the electrical circuit physics, simulate my device build with 100 piezoelectric systems in parallel ?
Ronan Hinchet.
4 Replies Last Post 22 dic 2012, 04:18 GMT-5
Posted: 1 decade ago 21 dic 2012, 11:10 GMT-5
Any idea ? Is it possible with COMSOL ? Did I miss something ?
Posted: 1 decade ago 21 dic 2012, 11:14 GMT-5
this is a rather common problem: how to simulate a complex system made out of N identical (assumed so at least) sub systems.
The Only way out, for me, is to carefully study PZT one system, alone, extract a system matrix for it (depending on which parameters in/out you choose) and then pass into a lumped system simulation, either with COMSOL and CIR, or perhaps SPICE, or a Modelica type tool, or even Matlab/Simulink
Hi this is a rather common problem: how to simulate a complex system made out of N identical (assumed so at least) sub systems. The Only way out, for me, is to carefully study PZT one system, alone, extract a system matrix for it (depending on which parameters in/out you choose) and then pass into a lumped system simulation, either with COMSOL and CIR, or perhaps SPICE, or a Modelica type tool, or even Matlab/Simulink -- Good luck Ivar
Posted: 1 decade ago 21 dic 2012, 20:51 GMT-5
I was hoping that I could find an easier way than that, but finally not.
Thank you a lot for your answer which confirm what I was afraid.
Ronan Hinchet.
Hello, I was hoping that I could find an easier way than that, but finally not. Thank you a lot for your answer which confirm what I was afraid. Regards, Ronan Hinchet.
Posted: 1 decade ago 22 dic 2012, 04:18 GMT-5
From this autumn COMSOL conference presentations, the deveoppers of COMSOL showed us (the users) that they are aware of this issue, and are looking into ways of including such model set-up inside COMSOL, we will certainly see some interesting devlopments in the near future.
Personally, I'm useing COMSOL for the details and MaplSim = Modelica based tool for the lumped modelling approach. I'm really looking forward for a COMSOL to/from Modelica facility, and a "super-element" feature in COMSOL, as now for large systems COMSOL is a bit too short. The Pipe flow module is a type of hybrid approach, for me, but still very interesting and going in the right direction ;)
Hi From this autumn COMSOL conference presentations, the deveoppers of COMSOL showed us (the users) that they are aware of this issue, and are looking into ways of including such model set-up inside COMSOL, we will certainly see some interesting devlopments in the near future. Personally, I'm useing COMSOL for the details and MaplSim = Modelica based tool for the lumped modelling approach. I'm really looking forward for a COMSOL to/from Modelica facility, and a "super-element" feature in COMSOL, as now for large systems COMSOL is a bit too short. The Pipe flow module is a type of hybrid approach, for me, but still very interesting and going in the right direction ;) -- Good luck Ivar
