How to calculate/record peak value of T variable?
I have a Heat Transfer in Solids model. I would like to know the peak temperature (highest T during the model time) at each (x, y, z) location. Is it possible to add an equation, something like
Tpk = (T>Tpk) * (Tpk-T) + T
I tried a few items under Mathematics without any luck. What's the correct method to do it?
1 Reply Last Post 8 feb 2012, 17:24 GMT-5
Posted: 1 decade ago 8 feb 2012, 17:24 GMT-5
use a maxop1(T) operator under "Definitions" ...
What is slightly poorly documented is that maxop1(T,x) (with 2 arguments) gives you the "x,y,z,r" respective coordinate, currently (in 4.2a) you get an orange warning error but it does still work. try a search maxop1(T,x) in the doc/help
Hi use a maxop1(T) operator under "Definitions" ... What is slightly poorly documented is that maxop1(T,x) (with 2 arguments) gives you the "x,y,z,r" respective coordinate, currently (in 4.2a) you get an orange warning error but it does still work. try a search maxop1(T,x) in the doc/help -- Good luck Ivar
