Out of Memory while creating mesh!!
I am trying to create a 2D model, wherein I import geometry from AutoCad.
The Problem is that the geometry is so huge, that I cannot form mesh on it, even with a very high element size.
Now, I cannot use symmetry BC, because it isnt symmetric bout any axis and I cannot scale it or redesign it.
So is there any way, I can solve this?
Is there a way to increase the memory allotment of comsol?
Will running the program on a supercomputer cluster help solve the problem?
Thank you,
-Rohan.
7 Replies Last Post 29 apr 2012, 02:58 GMT-4
Posted: 1 decade ago 11 gen 2012, 01:31 GMT-5
the only way I know about, and you will not be pleased, is to simplify your geometry, that is suppress small features that are not really relevant, replace complex struts by bars etc, it's quite some work
PS : forget the older versions, use only the latest one ;)
Hi the only way I know about, and you will not be pleased, is to simplify your geometry, that is suppress small features that are not really relevant, replace complex struts by bars etc, it's quite some work PS : forget the older versions, use only the latest one ;) -- Good luck Ivar
Posted: 1 decade ago 27 apr 2012, 07:23 GMT-4
I ran out of memory while creating the mesh
My structure is so simple..It consists of four layers and the thicknesses are in the micro or nano region
However, the width and length in cm... it took soo much time and could not create the mesh :(
i tried to make the length in the micro region and it created the mesh easily
but i need to to be in the cm region..is there any suggestion to solve this problem?
Thanks alot
Regards
Sally
Hi I ran out of memory while creating the mesh My structure is so simple..It consists of four layers and the thicknesses are in the micro or nano region However, the width and length in cm... it took soo much time and could not create the mesh :( i tried to make the length in the micro region and it created the mesh easily but i need to to be in the cm region..is there any suggestion to solve this problem? Thanks alot Regards Sally
Posted: 1 decade ago 27 apr 2012, 07:31 GMT-4
Hi there are a few ways:
one is to consider the thinnest (or a few of) and replace them by boundary physics
another is to use a distorted (scaled-stretched) mesh, I often use mapped mesh of a middle surface then sweep the mesh outwards with a given distribution (at least 3 elements per layer thickness as else you annot resolve a 2nd order equations nor gradient
Meshing is an art ;) training makes champion here too, but still start coarse and then check carefully by refining that your solution is mesh independent (more or less)
Hi there are a few ways: one is to consider the thinnest (or a few of) and replace them by boundary physics another is to use a distorted (scaled-stretched) mesh, I often use mapped mesh of a middle surface then sweep the mesh outwards with a given distribution (at least 3 elements per layer thickness as else you annot resolve a 2nd order equations nor gradient Meshing is an art ;) training makes champion here too, but still start coarse and then check carefully by refining that your solution is mesh independent (more or less) -- Good luck Ivar
Posted: 1 decade ago 27 apr 2012, 08:17 GMT-4
Thanks alot lvar for your prompt reply
Actually I am new to Comsol and i do not have experience with meshing and how to set the parameters for the distribution..etc
Do you have any document or tutorials of meshing thin films?
I want to try your second suggestion but i do not know how to do this
Thanks again
Sally
Thanks alot lvar for your prompt reply Actually I am new to Comsol and i do not have experience with meshing and how to set the parameters for the distribution..etc Do you have any document or tutorials of meshing thin films? I want to try your second suggestion but i do not know how to do this Thanks again Sally
Posted: 1 decade ago 27 apr 2012, 10:01 GMT-4
check the main web site with the videos, then do the exercices ... Also if you can make it take a few of the excellent COMSOL courses, there is one specifically for meshing but it's already advanced yo you should master the meshing well before going to it
Hi check the main web site with the videos, then do the exercices ... Also if you can make it take a few of the excellent COMSOL courses, there is one specifically for meshing but it's already advanced yo you should master the meshing well before going to it -- Good luck Ivar
Posted: 1 decade ago 28 apr 2012, 11:59 GMT-4
Hi Ivar
I am getting this error when i try to compute a stationary study..Do you know what does this error mean?
FYI: I am simulating an energy harvester on a flexible substrate and i used distribution for meshing
Error:
Failed to find a solution.
The relative error (18) is greater than the relative tolerance.
Thanks alot
Regards
Sally
Hi Ivar I am getting this error when i try to compute a stationary study..Do you know what does this error mean? FYI: I am simulating an energy harvester on a flexible substrate and i used distribution for meshing Error: Failed to find a solution. The relative error (18) is greater than the relative tolerance. Returned solution is not converged. Thanks alot Regards Sally
Posted: 1 decade ago 29 apr 2012, 02:58 GMT-4
check the KB (knowledge base) ;)
Hi check the KB (knowledge base) ;) -- Good luck Ivar
