Joule heating in superconductor
Hi~
I have a problem in Joule heating in superconductor
The Superconductor's resistivity depend on Temperature and "current density" both!
rho = f(T,J)
how can i handle current density?
Is it available to use expression of current density to put in rho value?
please help me~
2 Replies Last Post 30 lug 2010, 10:27 GMT-4
Hello Won Hee Sung
Posted: 1 decade ago 16 lug 2010, 21:50 GMT-4
Hi!,
It is extrange no one have responded to your question. I also have similar question, but I also want to add the magnetic field dependance, so rho = f(T,J,B)
Good luck!
Hi~
rho = f(T,J)
please help me~
Hi!, It is extrange no one have responded to your question. I also have similar question, but I also want to add the magnetic field dependance, so rho = f(T,J,B) Good luck! [QUOTE] Hi~ I have a problem in Joule heating in superconductor The Superconductor's resistivity depend on Temperature and "current density" both! rho = f(T,J) how can i handle current density? Is it available to use expression of current density to put in rho value? please help me~ [/QUOTE]
Sven Friedel COMSOL Employee
Posted: 1 decade ago 30 lug 2010, 10:27 GMT-4
this is sure possible with COMSOL. You can define functions of several arguments. The functions can be analytical where the number of arguments is practically not limited, but you can also define interpolation functions of at least 3 variables.
If you are using COMSOL 4.0a, please start Help > Documentation and seah for "Defining an Interpolation Function",
there spatial variables are given as an example but the function can be interpolated depending on a generic set of 3 input variables, e.g. T,J and B.
Sven
Hi, this is sure possible with COMSOL. You can define functions of several arguments. The functions can be analytical where the number of arguments is practically not limited, but you can also define interpolation functions of at least 3 variables. If you are using COMSOL 4.0a, please start Help > Documentation and seah for "Defining an Interpolation Function", there spatial variables are given as an example but the function can be interpolated depending on a generic set of 3 input variables, e.g. T,J and B. Best regards, Sven
