Inductance and Mutual inductance calculations
Hi All,
I am trying to calculate the inductance and Mutual inductance matrix of a multi turn coil of 2 layers. I want to excite current through primary coil and find the inductance, mutual inductance and induced voltage of secondary coil. I am attaching my model.
Thanks.
Pranith THummala
2 Replies Last Post 13 mag 2011, 18:23 GMT-4
Posted: 1 decade ago 13 mag 2011, 02:02 GMT-4
that looks good,
now have you checked the variables COMSOL has created for you, i.e. see
Results - Derived Values - Global Evaluation - Expression - Magnetics fields tab
or a CNTRL+ SPACE in the Expression entry line of the Global evaluation
Hi that looks good, now have you checked the variables COMSOL has created for you, i.e. see Results - Derived Values - Global Evaluation - Expression - Magnetics fields tab or a CNTRL+ SPACE in the Expression entry line of the Global evaluation -- Good luck Ivar
Posted: 1 decade ago 13 mag 2011, 18:23 GMT-4
Hi Ivar,
I am modeiling exactly the same thing. But the problem is that the global variable doesn't contain the mutual inductances
Please help
regards,
Omar
Hi Ivar, I am modeiling exactly the same thing. But the problem is that the global variable doesn't contain the mutual inductances Please help regards, Omar
