Problem visualizing Object in .stl format
Hello everyone!
I'm trying to import to Comsol quite a complex object in .stl format and Comsol gives me this error message:
Error: 2181
Problem visualizing geometry object.
Using wireframe rendering.
As the message states, the object is then visualized with a wireframe rendering and it is simply IMPOSSIBLE to set the boundaries or the mesh parameters. Comsol gets stuck or crashes.
Any hint/tips to solve this problem that is making me struggle?
Thanks a lot.
PM
4 Replies Last Post 6 mag 2011, 08:31 GMT-4
Posted: 1 decade ago 6 mag 2011, 07:59 GMT-4
Generally speaking, the stl format is not a very good way to import a geometry into an analysis package. Your posting does not specify where your stl file is coming from, but if it was generated in a CAD package I would recommend, if at all possible, trying one of the formats supported by the CAD Import Module: Parasolid, sat, step, IGS.
Posted: 1 decade ago 6 mag 2011, 08:01 GMT-4
My advice try to use a true 3D cad format, stl is (as dxf) not really there for 3D, it's that COMSOL cannot always identify where are the closed volumes from the wireframe info it receives, the format is not robust enough
Hi My advice try to use a true 3D cad format, stl is (as dxf) not really there for 3D, it's that COMSOL cannot always identify where are the closed volumes from the wireframe info it receives, the format is not robust enough -- Good luck Ivar
Posted: 1 decade ago 6 mag 2011, 08:24 GMT-4
thanks for your reply! The .stl format was generated by Amira. This software exports in .surf, .iv, .obj, .unv, .vrml and .wrl. In general, the two latter formats can be read by Comsol, but when I try to import them it says: "corrupted .vrml file". So it seems that .stl is my only choice.
[QUOTE] Generally speaking, the stl format is not a very good way to import a geometry into an analysis package. Your posting does not specify where your stl file is coming from, but if it was generated in a CAD package I would recommend, if at all possible, trying one of the formats supported by the CAD Import Module: Parasolid, sat, step, IGS. [/QUOTE] Hi, thanks for your reply! The .stl format was generated by Amira. This software exports in .surf, .iv, .obj, .unv, .vrml and .wrl. In general, the two latter formats can be read by Comsol, but when I try to import them it says: "corrupted .vrml file". So it seems that .stl is my only choice.
Posted: 1 decade ago 6 mag 2011, 08:31 GMT-4
Unfortunately, what I said about the stl format is also true about the vrml format. Stick to a true CAD format if possible. See Wikipedia for more info on the roots of the stl format (stereolithography) and vrml format (web graphics).
