How can i embed a 2D object into 3D
I have a cylindrical block and wanrt to insert a flat contact on top.
so i created the flat contact in workplanes, but i cant find the way to embed it into the 3D feature.
Any help.
Regards-LINDA!
1 Reply Last Post 2 apr 2011, 13:58 GMT-4
Posted: 1 decade ago 2 apr 2011, 13:58 GMT-4
you should do all your work in 3D if you are going to make a 3D geomtery. but you want to make 2D in your 3D work plane. then you extrude with zero distance your 2D geometry.
Mohamed Youssef
you should do all your work in 3D if you are going to make a 3D geomtery. but you want to make 2D in your 3D work plane. then you extrude with zero distance your 2D geometry. Thanks Mohamed Youssef
