Discussion Forum
How to simulate the process of laser overlapping deposition
Topics: Heat Transfer, 3.5
Thread index  |  Previous thread  |  Next thread  |  Start a new discussion
RSS FeedRSS feed   |   Email notificationsTurn on email notifications   |   7 Replies   Last post: February 9, 2012 8:47am UTC
MengMua Song
MengMua Song
March 15, 2011 10:18am UTC
Hi, everyone.
I am a new user of COMSOL. Now, I want to simulate the temperature field of laser overlapping deposition. This is a additive process in which material is added continously. I don't know how to model the additive process.
I wish to get help here.
Reply  |  Reply with Quote  |  Send private message  |  Report Abuse
MengMua Song
MengMua Song
March 16, 2011 12:48am UTC in response to MengMua Song
Re: How to simulate the process of laser overlapping deposition
May be, I have not presented my question clearly. What puzzle me is how to build the model in which the materials is added continuously. In other word, how to increase the domain of laser-depostited part.
Thank you.
MengMua Song
MengMua Song
March 17, 2011 1:36am UTC in response to MengMua Song
Dear Mr. Ivar, would you like to give some help to me?
Ivar Kjelberg
Ivar Kjelberg
Moderator
March 17, 2011 6:55am UTC in response to MengMua Song
adding material (or changing the topology) is a tricky domain ;)
It's not easy to start with, almost a full time project by its own.
I would suggest that you look at the "level set method" or the optimisation examples. As there are ways to approach material adding or removal by playing with the local material properties and boolean functions on them
MengMua Song
MengMua Song
March 18, 2011 1:10am UTC in response to Ivar Kjelberg
Hi, Ivar. Thank you very much for your suggestion. Now, I am going to adopt the way of controling the properties of materials.
Wish you everything to be going well.
Huang simom
Huang simom
February 9, 2012 7:26am UTC in response to MengMua Song
Have you solved your problem?
I try to use the ALE to present the material removal, but fail.
Could you give me some advice and guidance?
Thanks in advance for your help.
Best wishes to you and your family.
Huang simom
Huang simom
February 9, 2012 7:40am UTC in response to Ivar Kjelberg
Hi, Ivar
very brilliant help. I am still puzzle with the method you mentioned-the change of the local material properties. I know how to change the material properties with temperature (if in the heat transfer model). if only change the properties, the heat source-material interaction interface do not change. while actually, if there is material removal or adding the interface should move according to some quantity relative to the dependent variable(T -if in the heat transfer node). you also mention the Boolean function, the Boolean is only applicable to solid (am I wrong?). Could you give me a more detail?
Thanks in advance for you guidance.
Ivar Kjelberg
Ivar Kjelberg
Moderator
February 9, 2012 8:47am UTC in response to Huang simom
Check the doc and the model of the "loaded elbow" in the model library, its "solid/structural" but from my point of view also applicable, by similarity to HT
Rules and guidelines
